firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
I am trying to plan ahead as much as possible and was looking at my photos of the stock rear end. In the stock set up, the brake line comes back to the rear via a steel line, then when it gets to the back it has a hose that jumps from the frame to the rear axle housing. There is a steel brake line that goes across the rear housing to each brake cylinder.
So what set up do most people do when they put a new system in? I am thinking that perhaps the way for me to go is to run the steel lines to the back across the top (attach to the upper cross bracket that the shocks mount to at the top) and drop hoses to each side of the axle housing.....so what set up did you use...and any thoughts on what I am getting ready to do?
Herb
Herb
