delray56
I'm looking for advice from anyone who has installed side motor mounts in a C1. I have a 383 stroker (430 HP, 520 ft-lb) in a 1969 block, in my '62, with a Tremec 600 5-speed and 3.36 posi rear end. The bell housing was dialed in per Tremec's specs. The flywheel was resurfaced prior to installing the 383. I re-used a pressure plate that had 4000 miles on it, along with a new clutch disc.
Even with new, properly torqued front engine mounts, and a new transmission mount, I'm getting quite a bit of engine rotation and associated clutch chatter when taking off in first and reverse, and when downshifting. I've fought this problem all year, and after trying everything to reduce the chatter, I'm taking the engine out and welding in side mount brackets from Corvette Central. I'm planning to use Prothane mounts.
Because I fought the chatter issue all season, and knew I had to take the engine and trans out this winter, I decided to make a desperate attempt to "wear in" the clutch before shutting down for the year. I slipped it between 2nd and 3rd, 3rd and 4th, and going into 5th up hills. That didn't make the chatter go away, and I know I hurt the disc. Maybe I can tell, after disassembly, whether the slippage is coming from the disc and pressure plate, as opposed to the disc and flywheel.
I know I need to go with rack and pinion steering in order to accommodate the new mounts. I'm looking at a Steeroids kit. While I'm at it, I'll install power disc brakes. Because of the chatter, I plan to install an entire new clutch and flywheel kit to eliminate problem sources once and for all. I don't drive the car hard, and McCleod told me that a good street clutch kit will give the best chance of eliminating chatter.
Have any of you done this conversion, and are there any suggestions you have to pull it off successfully? And has anyone installed the rack and pinion system without power assist?
