This photo is of my original 1967 fuse panel.........since replaced.
What is the intended use of the terminal marked ACC? (I'm getting no voltage there on the new harness/panel)
What is the intended use of the terminal marked LPS? (I'm getting no voltage there on the new harness/panel)
Additional question -- what is the recommended method for obtaining 12volts "switched by the ignition switch" for auxiliary items?
