H
hatdragracer
I have a wire I cannot find in any wiring diagrams, it is dark brown in color and comes out of the main harness right behind the tach, it has a plastic shroud over a push on connection that is very similar to the ground wire that attaches to the cluster just above the tach. I can find no tabs to install this wire and to the best of my knowledge was unattached when I disassembled the cluster.
Also there is a small instrument light mounted to a half-moon shaped piece of metal with one hole that I have no idea where it goes. It was not attached when I removed the cluster.
Any help would be greatly appreciated.
