michael sommers
I am reinstalling power brakes into my car
I have several questions I hope members can clear
up for me.
1. Is there a gasket located between the booster and
the firewall? Is there a gasket with between the master cylinder and the power booster?
2. With my new booster came 2 round rods one about
2 inches and one about 4 inches long which one is used on a 67 is the other used on a different yr?
3. On the brake pedal lever there is 2 mounting holes for clevis one higher up than the other which one is
to be used?
4. There is a round felt filter on the booster actuation threaded rod. Is it to stay inside the plastic housing?
It wants to come out and ride on the rod.
Can this white plastic housing be rotated to better
align with the hole in the firewall? I see a gap in the
firewall due to misalignment.
I realize this is lengthy I would appreciate your insights
Thank you
up for me.
to be used?
Thank you
