Prior to installing the stainless trim around the front and rear glass, did St. Louis use any additional material, such as dum-dum, to help prevent leaks?
Ron Miller said:Looks like it could help prevent some of those mysterious water leaks under the dash that I've heard several folks ask about.
JohnZ said:Yes, they did (only around the windshield, between the rubber and the body opening and between the rubber and the reveal moldings) - P/N 3710409 sealing compound - greasy non-hardening black stuff - 13 ounces! They really slathered it on!![]()
67HEAVEN said:John,
Assuming that the sealing compound is no longer available, are you aware of a good substitute?
If not, how would you describe the consistency in the container. Probably far more liquid than dum-dum, correct?
Thanks.
JohnZ said:Bob, the sealer was pumpable, and was applied from a nozzle on a hose from a Johnstone pump that held a 5-gallon pail of the sealer. The stuff was black, and was about the same consistency as heavy chassis grease. A reasonable substitute might be 3M Bedding and Glazing Compound, as it's non-hardening and pliable. Check with your auto body/paint supply store guy and he may have another product that's similar or superior.![]()
