C3's Goodyear Tires ST or GTII?
Greekman
Parker, Colorado
'67 327/350-'73 LS4-'76 L48-'79 L82
C3's Goodyear Tires GT II or ST?
I have seen two different types of Goodyear replacement tires for original tires on many C3's. In the size of P225/70R-15.
The Goodyear Eagle GT II and the Goodyear Eagle ST.
What is the difference in the two tires? Could it be just speed rating?
Thanks for your responses.
Goodyear tires
Go for a set of 255 / 60R - 15 in the GT II's........they are the replacements for the Original Eagle GT's......Check out www.goodyear.com ..........they have all the specs
Correct Replacement Tire
My car came originally with the Goodyear Polysteel in the P225/70R-15 so would the Goodyear Eagle GT II still be the closest replacement tire on the '79 Corvette?
Goodyear isn't making the "ST"s any more. I believe they stopped production a couple of years ago.
I am not sure about 79 but 82 came with GT4's (I have the orginal set that came on the car in my attic). I put on the GT2's and are very happy with them.:upthumbs
Goodyear Tires
The 1979 Corvette...Standard tires P225 / 70R - 15....Optional tires P255 / 60 - 15. The 60 series look a bit nicer and fit perfect. The 'rollout' or diameter of the two tires are within 1/2"....The 1979 Corvette ordered with the Optional tire was a P255 / 60 - 15 Goodyear GT Radial, it was a Poly belted.....then came the Goodyear Eagle GT, it is Steel belted, the there was the Goodyear Eagle GT + 4, it was also steel belted, current tire is the Goodyear Eagle GT II, also steel belted.
Goodyear tires
Sorry Greekman, meant also to say.........yes.... the nearest tire Goodyear has to the 'Originals' are either the P225 / 70R - 15 or the P255 / 60R - 15 in the Goodyear Eagle GT II......
