L
ljbest
I have a 1996 C4 with about 70,000 miles. I have been bugged by what seems to be a periodic leak which I just figured out is ATF, not engine oil. A drip forms at the small hole in the tin cover near the oil drain plug and over time can make a spot about an inch or more in diameter. In reading the forums, I found references to overfilling of the trans causing leaks. I checked the dipstick (hot) and found the fluid level to be consistently over - up to the "S" bend in the stick. I had the dealer change the fluid last fall and have not driven this car much (Chicago Area) over the winter. Is it logical that this amount of overfill can be the cause of a leak like this? I intend to rig up some hose on a suction pump and remove some of the fluid. The Trans seems to shift fine and everything else seems to be fine - just looking for a second opinion on this situation.
-Larry
-Larry
