T
TACSC4
I have a 1988 Corvette that I installed a Hypertech Power Chip on I have also done the following:
Installed:
160 degree thermostat
Excel 24# fuel injectors
High volume fuel pump
adjustable fuel pressure regulator
new wires and #5 rapid fire plugs
intake manifold gasket
K&N open air system
air foil
and a TPS
When I am at a stop and I punch it, the car takes off then hesitates (for a split second) then takes off again, this just happens periodically. I was wondering if the chip has anything to do with this, and also if I have to put my stock chip back in can I still run the 160 degree thermostat or would that have to be replaced as well?
Any help would be appreciated
TacsC4
Installed:
K&N open air system
air foil
and a TPS
TacsC4
