c4 vs 4th gen camaro
  • Thread starter Thread starter redrdr80r
R
redrdr80r
c4 w/l98 vs 4th gen camaro
hi,
i am about to buy a c4 corvette (prob 85-88) and i was just wondering how it would do against my buddys 1994 z28 with an lt1
thanks james
Best answer....It depends. If you buy a 85 or early 86 you will get iron heads. These cars run ok, but and late 86 and up cars have aluminum heads that do make the cars run a little better. I have owned three Vettes, 86 iron head 87 aluminum head and now a 95 LT1. I also have some good experience with my brother's 94 Z28 LT1 and a friend's 2000 Z28 LS1.
If your friends Camaro is a auto and if he's not that great at the light then you sand a pretty good chance. If your friend is a little ham fisted with a 6spd then you have a good chance. You will increase your chances if you run 1/8 mile tracks rather than 1/4 mile. The L98 in the vette will stop breathing about 5000 rpm, however, the LT1 is just coming out of its torque peak and into its HP peak while on its way to 6000 rpm. This will let your friend to pull on you on a longer track. However, this is assuming that both cars are stock. If not, then all bets are off. It doesn't take a lot of money or effort to make either car run far better than stock.
Just for reference, my 87 auto on a fall night with a fresh tune up at Atlanta Dragway in Georgia ran 14.3
My 95 LT1 auto runs a consistant 13.7 at the same track (with traction control left on and not heating the tires). I see F bodies running anywhere from high 12's to low 14's.
Like I said, it all depends.
Brett
what rear gear do you have?
i'll say this. from a dead dig you got him in the 1/4 but if it's a roll race upto 100 mph he should have you then you'll go by him due to better drag coefficency. you got about 60 more lbs of torque than he does but he's got you by 65 hp.
i have no problems beating either LT1/LS1 Fbody's or C5's if they are stock or mostly stock.
ok thanks for the help,
but what about an 87 trans am gta or iroc? it would win right
Not a chance. The Vette has the Iroc by about 800lbs. All things being equal, the power to weight ratio of the Vette is much better than the iroc.
Brett
