c4c5/Vettechick Squeak in Rear Suspension
  • Thread starter Thread starter LA VETT
L
LA VETT
With all of your experience please see if you can help me on this one.
My 97 has a squeak in the rear suspension when I go over (slowly) a speed bump or dip in the road. I was told that you shouldn't spray anything on the bushings as it will loosen them up.
Any Suggestions?????
La Vett
HI there,
This is correct, nothing really should be sprayed on them.
However, there is a lubricant that we use, that is ok to use.
12345879 is what is used for suspension bushings.
I would give this a shot, and see how you do.
Allthebest, c4c5:hb
c4c5, thanks for the help. Is this a GM lubricant?? or something else??
Thanks again
LA VETT
