C5 door panel replacement
  • Thread starter Thread starter lcarlson001
L
lcarlson001
What do you have to do to remove the C5 door panels? I would like to replace my 1997 door panels.
Hi there and welcome to the Corvette Action Center!
A quick search using "remove C5 door panels" yielded this short instruction from our member and World Class Certified Corvette Technician c4c5specialist:
As for the panel, after you remove the 2 T30 screws, then use a large bladed putty knife, at the bottom of the door to remove the panel. It will pop with some good force, so just know that.
Besttoyou, c4c5:hb
Hope this helps!
:wJane Ann
