C5 + positive battery connection wire replacement
schnaker
New member
c.t.
2000 mil yellow coupe
Any body replace one of these, it splits 2 ways from the + terminal. One wire goes to the fuse box next to the battery and the other lead goes straight down behind th front wheel housing so it seems to replace this wire one must remove the wheel well to get to the lower connection. Any help or advice is appreciated. Thanks.
Eric
Eric,
Let me be the first to welcome you aboard.
I haven't replaced the battery connection wire, so I'll wait until someone comes along who has.
Tammy
I just replaced mine this past weekend. c4c5specialist is right about the access. It's a little tight but no big deal. If I remember correctly I used an open end 13. Be sure to put the cable back in the wire loom adjacent to the negative cable.
Good luck
Mike
