8kgold69
- Joined
- Nov 15, 2004
- Messages
- 99
- Location
- Sanford,FL
- Corvette
- 1969 R.Gold CV. Original 8K miles. Pilot 1970 LT1
Okay, I want to through a curve ball. 2003 convertible 50th anniversary with rear window defrost. On the left side (drivers) there is a black wire that comes out of the harness behind the shoulder belt and connects to the male adapter on the glass for the rear window defrost, which is the ground wire and on the right side (passenger) there is a color wire behind the shoulder belt, which is the hot wire. Both of these wires are wrapped up with all the other factory wires in the harness. The problem with the wires for the defrost is that they're too short. They have the factory black plastic clips on the ends, nothing has been cut, but again they are about 6-7 inches too short. The question is; is the harness the same for a coupe and convertibles and the factory supplies extentions for the convertibles because the top retracts? If anyone know the answer or if someone could look at their convertible top and see how the harness is wired for the defrost and let me know I would appreciate it.
