panrixx
What is the best starting procedure after a 18 month layup? My C5 has been garaged in an 'AirFlow air bag' but temperatures have been down to -10 degrees C.
Do I change the oil and filter first, or after giving it a run to drag any minute debris/rust into the oil filter before changing? The old oil had only done a few thousand miles and was Mobil 1.
Should I drain the 18 month old fuel from the fuel tanks and, if so, what is the best method?
Is there a way to 'prime' the oil before starting the engine? I know that older models could be primed via the distributor shaft, but what about a C5?
Are there any other precautions/actions to take prior to firing her up?
Any help would be very much appreciated.
