gkayvee
- Joined
- Jul 11, 2012
- Messages
- 26
- Location
- Memphis, TN Area
- Corvette
- 2002 Electron Blue Lingenfelter Blown Convertible
For a year or so, the cruise control in my C5 convertible would disengage for no apparent reason on a flat, smooth piece of road. Initially, no trouble codes were presented. However, as time passed, the cruise would disengage more frequently, until I had to turn-off the active handling system to use the cruise at all. It then began to give warnings to service active handling and service vehicle soon. That was what I was waiting for, because the warnings would probably present trouble codes that my mechanic could actually diagnose/fix. The codes indicated that the steering wheel position sensor was failing. As described in prior posts, replacement require$ removal of the $teering column. The part is still available from The General for $110, labor was about $350.
Funny part: when the prob first started, I read a post on CAC that the cruise problem was often caused by that sensor! When I told my mechanic about it, he was reluctant to replace the sensor without codes b/c of the complexity of removing the column. No more probs since the replacement.
