C5 Suspension Parameters
  • Thread starter Thread starter MarkEE
M
MarkEE
Please forward any information drawings / coordinates that anyone may have available for the C5. We are planning to run a 02 Z06 in SCCA T-1 in 2004 and need the initial suspension points. We are using Bill Mitchell's Racing By the Numbers software. We can supply a form if needed. We will make the results of the analysis available to anyone after we obtain the data.
Thanks,
Mark
HI there,
Really, if you are using the T1 suspension setup from GM performance parts, your setting should be there for baseline.
Then, you tune it during track tuning.
Please elaborate on what exactly you need, c4c5:hb
Thanks for your reply. I am using Bill Mitchell's racing by the numbers software to analyze the suspension of the Z06. Attached is a form that I use in the program. If you have the data to fill out this form I would appreciate your input and I will send the results of this analysis to you.
Thanks,
Mark
