cntrhub
- Joined
- Jun 17, 2002
- Messages
- 390
- Location
- North Hollywood, Ca.
- Corvette
- Miss my '62 & '80 4- Sp. Vettes
Crazy,
The harmonic balancer is a very busy part. It is attached to the front of the crankshaft. There is a rubber cushion that deadens the vibration characteristics of spinning mass, and acts as a mini-flywheel. It is designed to attach a main pulley, to turn the other components off the engine by using a single belt or multi belts.... for example, the balancer pulley might turn the components such as the A/C, Alt. P/Steering, etc. It's other function is to help set the ignition timing (if applicable).
It also goes by other names as, Torsional Damper. Basically, they add mass or inertia to the end of the crankshaft oposite the flywheel and in order to minimize the twisting of the crankshaft.
