Other than the lack of the halo bar, the convertible structure on C5 and C6 is not significantly different than the targa/hardtop structure.
As to the idea that the convertible structure could not handle the added torque of the "larger" Z06 engine is rediculous. It can handle the extra torque but what the convertible structure cannot do is provide as stiff a platform for the ultimate in handing performance as can the structure used for the targa and the hardtop.
Actually the Z06 hard top does have a steel reinforcement that runs around the back of the top up the back and above the door glass and up to the windshield posts besides the halo bar across the back like a Targa coupe!! The Z06 top is glued and bolted to the car!! I found this out when I replaced the Lt Quarter panel on my 01 Z06!! There are 2 screws that can not be removed without cutting 2 holes in the top, or raising the top up and removing them!! I chose to lift the top rather than cut 2 holes in it!!Other than the lack of the halo bar, the convertible structure on C5 and C6 is not significantly different than the targa/hardtop structure.
