C6 Dash Lettering Frustration
compyelc4
Dayton, Ohio
'95 LT1 Coupe, Comp Yell; C6 Roadster, Vel Yell
2005-2013 C6 CORVETTE DASH LETTERING LETTERS KIT - DOMED EDGES
I'm having difficult time getting letters to stay down, even after mucho cleaning of area with cue-tips and isopropyl alcohol. No way there can be any oils left, unless the vinyl treatment stuff has somehow actually permeated into the surface. Each time I cleaned the dash lettering area (where the stick-on letters are inserted) the cue-tip was removing black finish so I know there is no surface grime left preventing sticking. Any adhesive tips and tricks?
Hib Halverson
CenCoast CA
I have a 2012 but I'm not sure where the "dash lettering" area is. Post an image.
compyelc4
Dayton, Ohio
The lettering is smack dab in the middle of the padded dash console centered on the passenger side of the dash.
Shelby
Tinicum Township, PA
2007 Convertible 3LT
You need 2 things, 1. A good double face tape on the back of the letters, 2. the best way to deal with a good contact to the dash is to use 3M 4298 Adhesive promoter. It comes in a pen, and short sticks and small pads. I very rarely ever used the small pads, but the pen disperser and a Q-tip work wonders. I have never found Double face tape to stick very well without using #M 4298 product.
compyelc4
Dayton, Ohio
Thank you Shelby. 2nd set of letters seemed to stick, however to make sure I will try your recommended product this spring here in Ohio. Thanks again.
