B
BaileyMotorSports
Click here to view product
The DiabloSport Predator handheld programmer is now in stock and shipping. For those of you who have already placed your orders, they were shipped last week and the week before. We still have plenty of units in stock, boxed, and ready to ship.
The Predator 2005 GM 6.0L LS2 (part no. U7191) is applicable for the following vehicles:
* 2005 Chevrolet Corvette
* 2005 Chevrolet SSR
* 2005 Pontiac GTO
Why to get DiabloSport Predator?
* The flash tuner that allows for end user adjustability
* The flash tuner which accepts custom tunes directly from DiabloSport or from ChipMaster Revolution dealers that you can install yourself
* The flash tuner with built-in advanced diagnostic capability that displays fault codes along with descriptions of the code right on the Predator screen
* The flash tuner with data monitoring capability
* The flash tuner with a true graphical display that's 300% larger then the competition's puny text only display
* The flash tuner running on a custom high performance, multi-threading KROS operating system
* In house engineering and manufacturing is the only way to assure quality in every component. DiabloSport does it all, from molding the plastic to automated assembly of each product. Check out our virtual factory tour.
Dyno Tested Performance Tunes
The Predator was created with one thing in mind, POWER!
* Performance Tune: Designed to add power and torque using premium fuel.
* Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
Average power gains are in 10-20 RWHP range in the cars and 20-30 RWHP in the truck line. The Predators additional power makes itself noticeable immediately with an increase in power that starts in the low RPMs and builds into a frenzy at the high RPMs.
A Predator equipped vehicle will notice significant improvements in drivability. The additional power and improved shift patterns created by the Predator tune will yield quicker acceleration, firmer shifts and better mileage, whether it is in town or out on the highway towing an 8,000 lbs trailer.
The power increase in the lower RPMs will yield a better throttle response. The wider power band that the Predator creates will be particularly noticeable in city driving, where speeds constantly change. The mid-to-upper power increase is extremely useful on the highway when passing slower vehicles and to quickly maneuver out of emergency situations.
The increase in MPG is a byproduct of maximized engine efficiency, the improved timing curve and air/fuel ratio creates a more complete combustion, i.e. the engine extracts more power from each molecule of gasoline.
Predator tunes re-map the:
* Fuel Curves
* Timing Curves
* Torque Management
* Extend Rev Limiters
DiabloSport Performance tunes require the use of Super Unleaded / Premium grade fuel only, like carried by Amoco/BP, Sunoco or Mobil.
Adjustable Parameters
The Predator features end user adjustable parameters so the end user can customize his/her tune depending on other modifications done to the vehicle. Because we allow for timing and fuel adjustments the end user can optimize the tune for his/hers specific vehicle utilizing a dyno with proper air fuel monitoring and utilizing the Predator's live data feature to monitor timing and other vital parameters.
The Predator allows the end user to adjust the following parameters:
* Timing Table 1000-1800rpm (+15/- 40%)
* Timing Table 2000-3800rpm (+15/- 40%)
* Timing Table 4000-7000rpm (+15/- 40%)
* Fuel Table 2000-3800rpm (+/- 20%)
* Fuel Table 4000-7000rpm (+/- 20%)
* Idle (+ 400rpm / -400rpm)
* Rev Limiters
* CAGS ON/OFF (skip shift)
* COT ON/OFF (catalytic converter overtemp protection)
* COT enable time
* Fan Calibration
* Injector Adjustment
o Adjust for different injector size
o Adjust for long term fuel trims
[FONT=Verdana,Arial]If you have any questions about this product, please email justin@baileymotorsports.com[/FONT]
[/FONT]
[/FONT]
* 2005 Pontiac GTO
* Fuel Curves
* Timing Curves
* Torque Management
* Rev Limiters
* COT enable time
* Fan Calibration
[/FONT]
[/FONT]
