C6 Head Only Swap Dyno Results
  • Thread starter Thread starter silverc5vert
S
silverc5vert
Below is a graph of Livernois Motorsports C6 shop car with the only mod being stock heads ported by Livernois. NOTE: These are actual "uncorrected" numbers.
For photos of the swap and before and after shots of the heads, please go Here
Rick LeBlanc
I think that gain is demonstrated with bogus numbers.
It's possible they saw that much at the wheels after the head work, but I doubt the baseline number. In my opinion, it's way low. A tactic to make dyno results look better than reality is to degrade the basline number which can be done a number of ways.
Even if the base line was up around 340-345, where it should be, the gain is still notable.
Interestingly, when I interviewed GM Powertrain sources about the LS2, in the part of our discussion about mods, I was told if one installs the 02 LS6 camshaft and valves and ports the heads the gain is about 25hp....which is right where those dyno numbers are.
I know for a fact that it has a stock cam, and ONLY headwork (porting, valves, and springs). Keep in mind they are "uncorrected" numbers.
Here is a C6 graph I found on the Corvetteforum, look at his numbers...
pretty close to mine.
-Rick
HI there,
I would be worried.
My first c6 customer dynoed his 2 weeks after purchase, and he was running 357 at the rear wheels, 351 ft lbs of torque. No mods, six speed, Z51 with 1573 on the odometer.
I would be concerned if a brand new c6 ran 329/331 for numbers with a six speed.
Allthebest, c4c5
