C6 Rear Spoiler R&R Instructions
  • Thread starter Thread starter wheelsetc.
W
wheelsetc.
I saw instructions somewhere regarding removal and replacement of the third brake light spoiler but can't find it again. Can someone tell me? Thanks, Jim
Zip Products has instructions on R and R of door handles and spoilers!
Pictures also!
Here you go.
Tools Required:
1. 10mm socket/wrench.
2. 15mm torx-bit with driver.
Step 1: Remove the inboard two tails (1 on either side of the CHMSL) with the torx driver (1 screw holds each light to the fascia)
Step 2: Remove 10mm nuts (4 - total) that secure the CHMSL to the fascia. You can access 2 nuts from each opening on either side of the CHMSL. - (if using a socket wrench, you need a deep well 10mm)
Step 3: Unplug the electrical connector from the CHMSL (lift up on the tab and unseat the connector) prior to lifting the CHMSL off of the fascia.
Step 4: Gently lift the CHMSL off of the fascia.
