dplatt
Does anyone know the correct alignment specs for a C7 GS or Z (street use only)?
There are two sets of alignment specifications. One for FE1, FE2, FE3 and FE4 and a second set for FE5 and FE6?
What suspension is on your car?
Caster Camber Toe
[TABLE="class: all, width: 95%"]
<tbody>[TR]
[TD="align: center"]FE6, FE7[/TD]
[TD="align: center"]Front[/TD]
[TD="align: center"]7.4°± 0.6°[/TD]
[TD="align: center"]0.0°[/TD]
[TD="align: center"]−0.6°[/TD]
[TD="align: center"]−0.9°[/TD]
[TD="align: center"]0.10°[/TD]
[TD="align: center"]—[/TD]
[/TR]
[TR]
[TD="align: center"]Rear[/TD]
[TD="align: center"]0.0°± 0.8°[/TD]
[TD="align: center"]−1.1°[/TD]
[/TR]
</tbody>[/TABLE]
For street use only, you may find the camber setting too aggressive
If better tread life is the goal, I'd go for -02.5 front camber and -05 camber in the rear.
