Comp Cams
You can check Comp Cams website using their product search.
Here's a quick link to the one I found:
COMP Cams: XFI™ Xtreme Fuel Injection
The Comp Cams 252 XFI H13 with an RPM range of 1,300-5,300 seems to be mildest of the series. Uses 1.6 rockers to get the advertised lift INT .477 / EXH .472
I would e-mail Comp Cams Tech Support to verify that it can be run with the stock Crossfire intake/TBI 400's, stock ECM/chip & MAP sensor, stock 700R-4 converter and stock rear differential.
Back in 2008, I purchased this Comp Cams PN 12-308-4 with the following specs for my '82 Corvette Crossfire.
Back then, it showed as computer compatible, but now it shows as "not compatible for pollution controlled vehicles"....hummh, wonder if this is because they are pushing for their newer cam designs ?
This cam's RPM range is from 1,000 and uses stock 1.5 ratio rockers & springs.
Using 1.6 rockers will raise the lift to INT/.453 - EXH/.469
Haven't installed it yet as my stock engine setup still runs fine, but since I plan to change the timing gears as the original gears have the nylon gear teeth, may just pull the cam and put this one in since I have to drop the oil pan anyway to change the timing gear/chain and taking it one step further by pulling the instake manifold and radiator with the A/C condensor to the side still connected to the A/C compressor so A/C lines will be in intact.
COMP CAMS, part number12-308-4.
CAM SPECS:
INT EXH
ADV DUR 252 260
DUR @ .050 206 212
VALVE LIFT 425 440
110 LOBE CENTERLINE
Cam Grind # CS252AH-10
RPM RANGE 1000-5000
COMPUTER CONTROLLED FOR USE W/ TBI, CROSSFIRE & TPI 305-350 (This description was back in 2008, now it says "not for pollution controlled vehicles")
Stock GM L-83 Cam Specs w/ stock 1.5 rockers:
GM Cam # 14044613
Intake:
Opens BTC: 24
Closes ABC: 92
Degree Duration: 296 @Lash / 250 @.010 / 202 @.050
Lift:.410
Lobe Centerline: 114
Exhaust:
Opens BBC: 72
Closes ATC: 44
Degree Duration: 296 @Lash / 250 @.010 / 206 @.050
Lift: .423
Another way is just to change your 1.5 rockers with the 1.6 and your stock cam will have slightly more more lift- INT .437 / EXH .451.
Hopefully the ECM AFR parameters will be within its limits with this slight mod.
If you go with a newer, bigger cam & the ECM's program cannot keep up with the changes, then I would go the route of a 1227747 ECM with a HAM (Harness Adapter Module) to retain your factory ECM harness connectors & a Moates Ostrich 2.0 prom emulator for tuning on the fly. The Moates Ostrich2.0 requires soldering a 24 to 28 pin speed booster module for the Ostrich 2.0 interface cable. Other way is to use a prom burner, Moates Burner2, and a 24 to 28 pin PROM adapter for a 27SF512 eeprom which is flashable & electronically erasable. Programming would require multiple attempts until right parameters are reached. Both methods would require a tuning software like the CATS Tuner or Tuner Pro RT.
Hope this helps.
