cam info
socor7
Denver, Co
1976 White with red Int 4 speed
I just pulled th cam out of my broken engine, and wanted to know how i can figure out that specs on the cam and who it might be made by, with out measuring it (no tools to do that)
thanks.
number on cam are 0288
D-4
C-4
A-2
1
Drew
found some more numbers on the cam
it is a crane
hmv 278 2 nc
hope that helps
thanks in advance
drew
http://store.yahoo.com/cranecams/powhydlifcam16.html
http://www.cranecams.com/index.php?show=browseParts&action=partSpec&partNumber=113801&lvl=2&prt=5
Part Number:113801Grind Number:H-278-2 (REPLACES HMV-278-2)Engine Identification: Start Yr.End Yr.MakeCylDescription19571987CHEVROLET8GOOD IDLE, DAILY PERFORMANCE USAGE, MILD BRACKET RACING, 3000-3400 CRUISE RPM, 9.5 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500Engine SizeConfiguration 262-400 C.I.V Valve Setting:Intake.000Exhaust.000HOTLift:Intake @Cam3114@Valve467All Lifts are based
on zero lash and theoretical rocker arm ratios. Exhaust @ Cam3294@Valve494Rocker Arm Ratio1.5 Cam Timing:TAPPET@.004Lift: OpensClosesADV Duration Intake26 BTDC72 ABDC278 ° Exhaust80 BBDC30 ATDC290 °Spring Requirements: Triple Dual Outer InnerPart Number99848LoadsClosed105LBS @1.700or1 45/64 Open280LBS @1.240 Recommended RPM range with matching componentsMinimum RPM2500Maximum RPM5500Valve Float6500Cam Timing:TAPPET@.050Lift: OpensClosesMax LiftDuration Intake2 BTDC40 ABDC109222 ° Exhaust56 BBDC(2) BTDC119234 °
Thanks that is the one I am sure of it
Drew
I pulled my 82 engine and did a total rebuild. Socor has a cracked cylinder, so he has to do the same.
cam pull
well I have yet to pull the engine, but to take out the cam I have taken out the radiator and fan assembly. water pump harmonic balancer (need a puller) and then timing cover and chain then took the the lifters and rods out, and losened the fuel pump. then just pulled the cam out.
quite a bit of tear down to get there
drew
Believe it or not, Drew, it will take half the time you already spent to pull the engine. :)
yah I am sure of that but I wanted to figure out the problem before I pulled the engine cause it might have been just a head gasket. I also don't have a puller or an engine stand, but they will be on the to get list. I am going to pull the tranny as well, to inspect the tranny and clutch. and it has been useful having it in to measure for intake and carb height, to see what will fit under the hood.
Thanks for the reply Drew. Shop wants 6-8 hours to do it. Maybe I'll just let them at it. I hate doing that. They seem to fix one thing and break another.
Jim
C'mon Jim,
You have spent so much quality time with that 82 you know how to do it. You know all about the Crossfire and not many shops do. 8 Hours doesn't seem like enough time to do it right. They will have to do the whole tune up afterward and there's a lot to mess up there.
You can do it!
Or come on down to Rochester, and I'll help you!
Pete
yah you can do it.
I enjoy taking things apart, and figureing things out. but now I am down to a decesion. zz4 short block, or a 330 hp vortec long block.
