R
RLP
I am buying a 80 Corvette without engine auto trans. I have access to a 79 Camaro with auto trans. Would this be an easy swap? Would most parts work? eg. water pump, pulleys, Thanks
RLP said:Do any other GM product in 350 V8 use the short leg water pump besides the Corvette? Will the frame mounts and motor mounts be differant on the Camaro? And finally will the wireing have the same plugs? Thanks for the info.
