M
MagikDraggin
I had a situation awhile back where the gasket for the TB was allowing coolant into intake manifold.
I've heard (read) that this is death for the 02 sensors and will dramatically screw up the A/F ratio.
First of all, is this true about the coolant messing with the 02 sensors, and if so, can they be cleaned, and if so. how?
Final question, when cleaned (or replaced) how can I determine if there is any difference in the A/F ratio short of doing a dyno run with a wide-band 02 sensor?
