Vette/Berlina-coupe
- Joined
- Nov 18, 2002
- Messages
- 284
- Location
- southern california
- Corvette
- C3-coupe/MercedesBenz-540K replica! Racing-SB-V8!
a.) Wondering if i can tap the oem 12v. wire which clips-in (white plastic fitting which pulls-down to remove) to the HEI-distributor; --would like to simply run a wire to the Rochester-carb's. Elect.-choke's male-terminal, --or would that possibly interfere with distributor performance?
b.) Also, the Tach. was working perfectly prior to having done an eng.-R&R, -the eng. runs terrificly now but the Tach does not operate, -only floats up a few hundred rpm's when Ign. turned-'off', and quickly moves to '0' when Ign. is turned-'on', yet stays at '0'-rpm's when engine is running!! Cannot find any wire having that special clip that would plug-in to the Tach.-receptacle on the HEI/distributor-cap! --Or is the oem-Tach. somehow fed its timed-signal some other way?
c.) Is the Tachometer fused? --if so, what Fuse-terminal, and what amperage-rating?
Have the Vette factory-manuals and a large color/wiring-diagram laminated in plastic, --unfortunately these vital references are presently buried in storage after moving...
Please advise... ~Robair
