MacD2469
I have an itch and need to scratch it. I want more that the Econo horsepower I presently have.
The car needs to stay smog legal because I am going to Germany this August. I want to put it in the 82 and use the crossfire injection system. Here are the specs I have for the motor.
-Cam: Comp Camps grind CSXR270-10 (Full Roller)
duration@.050 intake 218 exhaust 224
lobe lift intake .3300 exhaust .3350
lobe separation 110
-HEADS: L-31 no mods
-Pistons: Hypertectic flat top
-Block: bored .030 over
I know I am going to have to put a different PROM in the computer but don't know who to talk to or where to begin.
I have to modify the heads to accept the old style 12 bold crossfire intake manifold. The L-31 head is 8 bolt vertically drilled.
Another option I have is to use a newer TPI from a Camaro I have that uses a two injector throttle body to put on the present manifold (Performer with a Holly 4150 bolt pattern).
I can use the wiring from the old single injectors to wire up the double TPI. But don't know I don't know if there will be enough vacuum to work with the MAP sensor yet.
I really need to talk to someone who has done something like this..... Hopefully someone has tried this....
Mac........... Any help and insight very much appreciated
lobe separation 110
