garyg
Problem started when I got an OBD code 36 indicating Mass Air Flow sensor, so I cleaned it with CRC remounted it and resulting codes are 12, which is normal. Next car would start but shut down immediately, I could tell it wanted to fire. I suspected the fuel filter ( tackle easy things first ) I replaced it.
Still, Vette won't fire up. I tested the fuel pressure at the fuel rail with a gauge, reading with only the ignition on is 40 lb. If I spray starting fluid in intake car will fire up strong then shut down. I am getting no other codes on the OBD except 12.
I would appreciate input from a more experienced Vette owner.
