This is a strange problem. I can raise the temperature but I can't lower it so it eventually gets stuck at 90 degrees. I've tried going into the diagnostic mode to view the codes and I'm not getting any error conditions. No errors at start up either. This problem seems to come and go. I currently have the battery disconnected to see if that works.
I guess the control unit could be bad?? No other problems with it other than that.
(1996 coupe)
(1996 coupe)
