Question: Car dies temporarily going around corners
OK so it really didn't fix the problem, now it cranks like crazy but no fire, I have the proper fuel pressure according to the fuel pressure gauge but the plugs are dry. Is the Presurre regulator before or after the schram valve where the pressure guage screws on. Really thought I had this fixed. My kids think its my wife haunting me since she bought it for me a couple of years before ALS took her.
No fire? As in no spark plug fire? Or as in no start?
Do complete fuel pressure tests - static and dynamic.
Static - motor off.
Check what primed pressure is - turn the key on, and not the pressure. Note bleed-down time also, and write it down.
Dynamic pressure - motor running.
Idle with vacuum off of FPR - write it down.
Idle with vacuum ON FPR - make note.
Then, pedal down pressure. You might be the first one who I think definitely needs this part of the test. You need a hose extension, to tape the guage to the windshield. Then get onto the road, steady speed - 45 or so, and accelerate, just enough to drop the tranny to second. Note the pressure change.
Post back on it...
No start and I have the correct fuel pressure when the key is turned on. but it does is crank over with no startup. and the pressure holds.
That only means the pump has primed the injectors...it does not mean that it can keep up. Priming is only 2 seconds then it shuts off until the engine fires.
Once running the engine can easily suck the system down if the filter is clogged or the tank sock is plugged or a worn pump. Thats why the need for test key off AND while running.
NOTE:
the way the needle on the gauge behaves means EVERYTHING.
if the needle dances around while idling, any, something is wrong with the pump/filters. The needle should be stable until there is a change in RPM (demand for fuel) and that should be smooth. The pressure should drop slightly during cranking to indicate that the injectors ARE operating. Confirm with Noid.
Having static pressure does not mean that the injectors are operating. It just means there is pressure on them. The injectors still need a good signal to open. Use a "noid-lite" to see if the injectors are getting a signal. $8 tool at most parts stores.
No fire, if thats been proven by the removal of a spark plug wire and grounding on the block while cranking, or the use of a spark tester lite, go back and look at the wires to the distributer. Especially the 2 on the outside,. There are 3 in a plug that snap in behind the 2. I have seen a loose batt wire that would kill the ignition in right turns, and finally came off and killed all spark. Also the wires inside the cap that run from the edge of the dist base to the inside module get damaged by the cap pinching them and they will ground out or wear the insulation off. Finally, the module itself or its plug.
Look closely at the red Batt wire to the cap. its the heavier wire on the right. Left is the tach wire. The cap/coil needs to be cleaned periodically. The contacts corrode and even break off under the coil. Check that ground tab on the coil.
But the plugs are dry, and yes the pressure does drop slightly while cranknin. The engine was rebuilt last year ( not by me but a shop that specializes in vettes ). New injectors fuel filter, new fuel pump, new sock on the pump and has less then 800 miles on the new engine. Funny there were times when it would not run for a couple of days then it would run fine, damn thing is driving me crazy, luckly I have my 96 LT1 as a backup. The main thing is that the plugs are DRY. I would take it back to CnV corvettes in Tempe here in AZ but they closed and went back to just doing upholstery. May just have it towed to a shop and have them diagnose the issue. Son in law is coming over this am and we will take another stab at it.
How bout the Fuel Pump Relay ???
Maybe don't think 'parts'.
It would be nice if you just do the Fully Automatic Assault Wallet repair, and swap-a-part in 15 minutes fixes the problem, and if you're rich, then pull the trigger! 1655.gif But buying parts blindly is not the best idea (and I have interest in auto parts retailers' index funds - they are doing WELL)
But do the dynamic FP tests. It ain't hard...
(ed.: ok, you have a no-start)
Air, fuel, fire.
Fuel - what exactly is the static fuel pressure? And how long before it drops? This is important how fast it drops.
Air - filter clear?
Fire - plugs and wires good?
But the plugs are dry, and yes the pressure does drop slightly while cranknin. .
Thats how they should be.....this is fuel injection, nowhere near enough raw fuel to make a plug wet unless the injector is stuck open or shorted.
If the pressure drops slightly as it cranks that indicates that there are pulses that are using the stored pressure. Again, it will not run the fuel pump after priming UNTIL the distributer sends a reference indicating a "run" condition which you are not getting.
Was spark tested? new parts and new engines with old parts fail as often as anything else. Now that I hear its a fresh rebuild, I am almost positive that you have a loose power wire at, in or to the distributer , IF you do have 40 psi fuel pressure at key ON. Poor connections almost always come from connections that someone has taken apart recently.
The fuel relay is ok if the system runs the pump with key ON to prime. There is a backup power source anyway.
OK its running again, the coil wires were fried. Replaced and she's running again.
Thanx to everybody trying to help me solve this issue
Gordon
Cool!
How many coil wires did you end up replacing?
the 3 wires coming of the coil somehow were fried and turned into 1 plastic wire mess. No clue as to why. Just replaced the entire coil.
Gordon
Makes more sense.
I was thinking how there's more than one ignition coil wire... (unless you got Del-teq, or LS1)
