mcditalia
Ok, beautiful day today, so went to the beach,
On the way back, I'm on the hyway and the car starts to hesitate a little bit, like it' running out of gas. Ok, I was low about an 1/8 of a tank, pull over check the tank and there's definitelly gas in there, not too little to make me run out! Start up again and cars is running fine for 5 minutes or so, and the bucking starts again, so bad that it dies. Try to crank the car, starts and dies again. All other tries, no deal.
Pull the gas line from pump to filter to see if the filter might be clogged. Crank the car a couple of times and no gas coming out from the pump line. OK has to be the pump.
Wait for AAA (2 1/2 hours) and get the car towed back home. Just for kicks I crank the car in the garage and sure enough starts right up. Didn't wait to see if it died again, because of fumes, so let it run only for a couple of minutes. So any thoughts?
A week ago, I had the sending unit replaced in the tank because it wasn't working right. Any connetion between the problem and this recent fix that anyone might think of, or is it the pump?
