Carb Adjustment
matthud
WNY
1969 LeMans Blue Coupe
Can someone tell me how to adjust the idle on a 69 with the 4 barrell carb?
4 barrell what?
I will assume you mean a Quadrajet carburetor. Remove the air cleaner. Look for where the throttle linkage attaches to the carb (driver's side). On the carb, it will be like a little "ear". Look behind the ear and you'll see a standard head screw on a horizontal plane-passing through a small spring. Move the throttle open a couple of times and you'll see how it rests against this screw. You'll need a small tipped screwdriver and approach from the front, turn clockwise to raise engine speed.
Suggest you check ignition timing (distributor vacuum disconnected), and also check/replace the PCV valve-confirm it is the proper application, I believe AC CV36-I can confirm later if you need to know-books at home. This affects idle as well. Ideally, use a vacuum gauge and adjust your idle mixture crews.
if it is a Holley, it's very similar only the screw is on a vertical plane. Again, the "ear" and you'll see the screw between the front and rear barrells.
Carter and Edelbrock will also be similar. Just wiggle the throttle a few times and you'll see the screw. Piece 'o' cake...:)
Rick
While you're post, how do I properly adjust the choke and fast idle speed--QuadraJet? Thanks!
Choke and fast idle
I see you have a '77, w/ Q-jet. Is yours a divorced (thermostatic coil w/ rod) choke or the little round "can" on the side?
Here, I will guess it is a divorced choke. First, make sure the choke pull-off works correctly. You'll need a vacuum tool-MityVac or other. You can do all this on a warm engine.
You'll also need the specifications. Suggest the GM Service Manual or you can purchase a carb kit to get the spec sheet and rebuild the carb another time. A carb kit spec sheet will also give you a nice picture of the carb and identify certain bits. Disconnect the thermostatic coil rod from the carb. Next, open the throttle, close the choke plate completely and release the throttle. I assume you know what/where the fast-idle cam is. Slowly push down on the "ear" of the cam until it clicks to the second step. A rule of thumb is a 3/16" drill bit should just pass nicely between the choke plate and the front/side wall of the carb throat. Next, use the MityVac to open the choke pull-off. Measure the choke plate opening again. 17/32" comes to mind here but I could be wrong.
The fast idle screw is below the fast idle cam. Reconnect vacuum line to choke pull-off. Since the car may be warm, and the choke is already situated on the second step of the fast idle cam, start the car and use a 8" or so long regular small tip screwdriver to reach in under the cam and get to a small screw located real close to the secondary lock out tang. High idle should be about 1500 RPM. The spec sheet will tell you, also.
I have made a few assumptions here regarding your familiarity with Q-jets but it really is not too difficult and will allow you to properly "bond" with your machine. ;)
Take your time, look it over and get familiar with where everything is and you'll impress your friends and amaze your enemies. Good luck.
Rick
Fractionally challenged
Sorry, folks, I was a little off:
This should give both Matthud and photovette a good start-
The first adjustment (choke rod) is 3/32" vs. 3/16".
The second (choke pull-off) is 17/64" vs. 17/32".
PCV valves as follows (AC Delco):
1969 350/427 4 bbl.: CV 736C 427 3X2 bbl.: CV746C
1977 350 4bbl./std. trans. CV 774C 350 4bbl. auto. trans. CV775C
All the best. :)
Rick
