jracer49420
I have a 74 that is hard starting when cold. I was told that the float level in the carb should be checked. I have a Q4 on this vette. Can anyone tell me how this is done? Thanks
If you just want to check the level before pulling the carb apart O.T.C. sells measuring sticks that fit down the vent hole and will give you a pretty accurate reading to see if it needs to come apart for repair. make sure your choke closes tight and that the pull-off is working .these carbs also had issues with leaky lead plugs in the bottom of the bowl this would leave the bowl dry and let gas run into the engine a bowl at a time if left long enough:ugh Steve
