Cat Heat Shields
B
bdisanto
I need idea's. I took my front y pipe off to change the starter, in doing so the heat shields around the two small front cats came off, the pipe is fine and was put back on, ( minus the heat shields). Does anyone know of an aftermarket shield available, or are there any idea's to create something that will work?
Ben DiSanto
Tallahassee, FL
none right now :(
you may want to try a corvette salvage yard first... you may be able to get a replacement set... otherwise, home depot or lowes should have something that would work... if not, exhaust wrap could work (however it has been said that it causes moisture buildup, which leads to rust)
