Ed's 1970
I just received my first corvette ever, a 1970 t-top 4 speed.
The engine block is stamped CEB1465 on the front pad. In the back near bellhousing it is stamped 3970010. I researched the 3970010 and found out it is probably a 4 bolt-main block/forged crank used in trucks and corvettes. I could not locate the block date code yet. The heads are 3991492. I am probably going to verify internals by removing the oil pan. Does anyone know what the CE code stands for?
Thanks,
Ed
Thanks,
Ed
