cwerve74
This seems like a silly question concerning my 1974 M/T Need to do an R & R on the parking brake and want to remove the center console that covers the parking brake handle . I remove the screws that hold the consle from the sides. The front will move up several inches but it seems to be attached at the rear wall. Using a mirror & light I can not see enough to disconnect the console. It almost seems that you need to remove some sort of fassener from the under side of the car above the differential. Is there a trick to removing this part or can some one describe how the rear of the parking brake console connect to the body?
