minifridge1138
Hey everyone,
My base timing is set at 12 degrees.
I'm working to get my centrifugal advance to be all in by around 3000 RPM.
The only springs that get it there start too soon and provide 13 degrees advance at idle. This combined with my base and vacuum produce 40 degrees at idle, and that seems too high.
I have another set of springs that provides 2 degrees at idle, I don't know when they are all in (I stopped revving when I got close to the orange line on the tach).
The only solution I can think of is lighter weights.
If I reduce my base, that will lower my idle but will also reduce my advance when the centrifugal is all in.
Does anyone else have any suggestions?
