T
tonylong
I've decided to change the ATF, filter, etc. and have all the GM parts.
I know removing the pan only changes some of the ATF. If I also suck ATF out thru the filler tube at the same time will I get much more fluid out, or am I just drawing from the same pan anyway.
Also - is there anything special I need to know about removing the X-brace in dropping the pan. My mechanic is nervous about putting strain on the frame in removing that brace.
TIA
TIA
