G Winter
low injector ohms means they are bad?
I have been having some rough running issues for some time. I finally found the time to check into it. I took ohm readings on the injectors and 6 of them were 16.1 to 16.4 ohms. number 2 was 9.3 and 8 was 7.1 I assume this means those two injectors are bad ? Before I run out and buy two new injectors I would like opinion on this. Also should I replace them all with the ohms being so close to specs I wonder if it is throwing away money. Another thing, do I need to get matching injectors , is mixing brands going to unbalance the injector system ?
thank you.
Glenn
thank you.
Glenn
