FRANKD
Has anyone had this problem; after a ride sunday i pulled into the drive way and my choke and battery light came on. The engine idles around 1400 rpm for a few minitues when it is cold but drops off like the choke is working. I unplugged the wire to the choke on the carb and the light went out but the rpm's did not drop.The volt meter is only reading about 9 volts and it normally reads about 13. Could i have a short in something or maybe a bad alternator .:confused
