CI rearend rebuild info
Texas
1962 rebuild in progress
Can anyone point me in the direction for a supplier for bearings and seals for a 62 non posi rearend (not sure of the ratio as I am still scraping off the undercoating). Are there kits available? Also looking for some form of repair manual or directions for the same. This unit has been sitting for about thirty years so I figure to replace all bearing while I have it out. Thanks for any input.
Thanks folks I appreciate your recommendations and will follow up with a contact. One more favor if possible. I have found the casting number and date code ok but am having trouble locating the axle code to determine the gear ratio. Corvette by the numbers mentions location on front right of the differential carrier at the same height as the axle tube but no luck yet. I think its probably a 3.36:1 but would like to know for sure. Thanks
