Ken's67
I'm in the middle of detailing my engine and engine compartment. I removed the engine from the engine compartment to repaint the motor. I also removed the heads so I and check things out while the motor was out. My question is: Is there anyway to remove the "Carbon Buildup" on the piston tops and heads? Is there a solvent or a solution that will break down the carbon? Thanks
