R
Richard Cooper
I noticed there is a BIG difference when comparing my clutch fan to another 81. Mine is very hard to turn (when engine is off) a friend also has an 81 and his is very easy to turn. On his the fan keeps rotating by itself for a few seconds, but mine is so hard to turn that as soon as you stop pushing it it will not turn on its own. Can someone tell me which one is normal? I found this difference while trying to locate a vibration. There is about 1/8 of an inch of play in fan when moved from side to side. I have to check close to make sure the play is not from the water pump, but I wanted to find out about the clutch fan first. Thanks in advance.
