On my 90 the clutch was only slipping when the car was warmed up. Seldom slipped when it was cold. I chased the hydraulic clutch system for over a yr. What seems to have been happening on mine is that the seal in the flywheel was leaking. The lube in the flywheel must be heavy and only leaked when it got hot. Eventually it wore the clutch disk enough that it started to slip when cold. Personally I wouldn't replace the disk on a dual mass without replacing the flywheel. Seems the dual mass flywheels are near impossible to find now so you may have to replace flywheel and clutch with a non dual mass replacement.
What I have been seeing is if your hydraulic system is giving trouble you will have trouble shifting because the clutch don't release all the way.
Glenn
