L
lytemup
Hello, finally just got my 81 out of storage today (or tried to). When I went to put the car in reverse it just grinds the gear as the clutch is not disengaging. It will not go into any of the forward gears either (doesn't grind, but if I push a bit harder it drops rpm as it starts to load the engine). I pushed the car foward a bit just for giggles but that didn't change anything. Had the wife push the clutch while I checked the linkage and everything appeared fine.
The car has <20k original miles, and has been driven <100 in the last 5 years. It also did not show any signs of a worn clutch when I put it away last year... so I'm quite surprised that it would have gone out...
So my question is, how do I truely diagnose this, could it just be 'frozen' together? Anything else it could be?
Also of note when I unzipped the big baggie I keep it in was the car seems to have peed a large amout of what looked to be P/S fluid, but I'm pretty sure C3's did't have hydo clutches (& mine's all original).
I like to fix this myself if nothing else for the learning and enjoyment of it, but I am obviously not a mechanic. I am actually an engine engineer though, so I'm not starting at ground zero.
Thanks for your help!
EDIT: thinking about this more. I store it in one of the zip up bags, pretty much air tight. the P/S fluid leak caused some mold on the bag and cardboard i placed under the car, so perhaps the clutch is rusted to the flywheel given the extra condinsation right in the area?? hmm..how to check, test, free that...
