L82GEM
Hello out there. I have a 1979 L-82 4-Speed. There is a bit of side-play in the clutch pedal. Is there any procedure known to properly change this bushing to eliminate the slop in the side-play. It appears you would have to drop the entire dash assembly on the drivers side. The total side-play is approximately 1/4" to 5/16". Your input would be greatly appreciated. Dale W.
