like2drive
Just got the Muncie installed on July 2 after removing old automatic.
This is being done "on the side" and "when they have time " at a popular transmission shop in our area. It probably took about 6 hours over a 5 day period. Driving me nuts!
The Guru mechanic-friend of mine that owns the place, found he couldn't adjust the clutch out in the closing hours for the Fourth vacation. Car is still there. He says I have the wrong throwout bearing (I bought all the parts), and that I need a longer one. Trying to save the day, I ran to the Clutch distributor to get the longer T. O Bearing. The "specialist" there said I probably hadd the wrong pressure plate...a flatter plate if we were needing a longer T. O. Bearing. Also, he agreed that the longer brg could solve the problem.
However, he also sold me a pressure plate w/ a more pointed, angled fingers which would cause more pressure he said I needed in a Vette. This plate would use the shorter throwout bearing.
I returned to the Guru at the Trans. shop just as they were packing it up to close for the vacation. Both solutions are at the shop when they return.
I'm being charged by the hour. It'll probably be two hours to pull the trans and old clutch out and install the new. Should I use the better pressure plate that will require this extra time, or just switch to the longer T O Bearing? (less time). I'm leaning towards going back to scratch with the "better" pressure plate. What would you do? anyone ran across this before? thanks in advance. jim
